a4 1.8T MAF sensor
Old Oct 12, 2011 | 11:07 AM
byrnedave's Avatar
Default a4 1.8T MAF sensor
Hi Guys,
Im looking for an engine diagram for a 2003 a4 1.8t. Iv had an alarm for the MAF sensor. I want to take it out and clean it myself. Any tips on taken it out would be great too.
Thanks
Old Oct 12, 2011 | 11:23 AM
byrnedave's Avatar
Sorry forgot the code number. P0171 Fuel Trim,Bank1 System too Lean
Old Nov 20, 2011 | 04:22 PM
Kubelwagen's Avatar
Just off hand, that code doesn't sound like the MAF. The lean fuel trim code generated in my Passat with the same engine, indicated a vacuum leak. Generally its a leak directly off the intake manifold somewhere. In my case, a small hose connected at the front of the manifold that came loose from an emissions component under the manifold. A new clamp on the hose and the code never returned.
Haven't had this particular lean fuel trim code generated in my Audi. But I don't think it's different from the VW. Regardless, removing and properly cleaning the MAF on occasion is good maintenance.
Old Nov 21, 2011 | 06:26 AM
byrnedave's Avatar
Thanks for the reply.
Turned out to be a breather problem. New breather valve installed and now back running smoothly.
neomaxddr
Apr 1, 2009 03:16 AM
