Automatic shifter button not releasing.
Old Mar 9, 2009 | 01:44 PM
inetforce's Avatar
Default Automatic shifter button not releasing.
This is a 2002 Audi A4 1.8T Auto.
The shifter button is not releasing and the lock cylinder is therefore not releasing the key. I have to shake and some times hit the shifter a bit for it to release the button and then allow me take the key off the ignition.
Is this a common problem for this car? How can I fix this?
Thanks in advance.
Old Mar 9, 2009 | 02:08 PM
shane.trammell's Avatar
I've never heard of this. I would assume the shifter would need to be replaced. You could try spraying some wd40 or contact cleaner into the button to see if that loosens it up.
Old Mar 10, 2009 | 10:09 AM
inetforce's Avatar
shane, someone suggested the brake light switch. Supposly this switch controls the shifter button.
What do you think?
Old Mar 10, 2009 | 10:23 AM
Myst420's Avatar
What do you think?
That would prevent you from shifting OUT of park and not into park. I would try, as shane stated, some wd-40 or similar.
CarpAudi
Feb 26, 2015 05:55 PM
taylor123
May 23, 2012 05:35 PM
dogchainx
Jul 29, 2010 08:45 PM
shady927
Apr 15, 2008 05:19 PM
jlinaschke
Feb 9, 2007 10:17 PM
