AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   B6 1.8; dead battery, timing belt change, rough idle (https://www.audiforums.com/forum/b6-models-70/b6-1-8%3B-dead-battery-timing-belt-change-rough-idle-189155/)
huntdavid Nov 8, 2012 10:59 PM
02 B6 1.8t; overheated and towed it home. Changed the timing belt and water pump, thermostat and coolant flange. Recently replaced coil packs and plugs; after the timing belt change and coolant flange/thermostat replacement i started it up and it ran like a top except for a leak on the coolant flange. I replaced the o-ring and put humpty dumpty back together again and it runs rough, like on 3 cylinders, after having to jump the battery. The battery had been dead since it was sitting for a few months. I jumped it and it ran very rough. Plugs were black when I pulled them. Wire brushed them and gapped them again. I had to replace a vacuum hose that was under the intake manifold and the oil rebreather tube. I haven't checked any codes. It ran great while it was leaking but now runs like hell. Needing some suggestions on what is next besides charging the battery. Thanks in advance.
pa4ul Nov 9, 2012 12:33 PM
u might still have a vaccum leak. is it studdering and all?
huntdavid Nov 9, 2012 10:56 PM
yes it is studdering; I'll investigate the vacuum lines. I had to replace the L and T breather hoses (ECS tuning ES#2214900 ) and the breather hose (ECS tuning ES#277547 ). i didn't change the PCV, maybe those have given up the ghost too. I'm betting they are were original parts with 144k miles on them.
Thanks!
