B6 with a system...
Old Feb 8, 2008 | 08:49 AM
LowClassA4's Avatar
Default B6 with a system...
Anyone who has installed RCA outputs right off the factory amp...
have you had any problems with noise out of the sub. i got a new amp and when i hooked it up, i had some nasty noise coming out of the sub..not bass but more like a "whine" or maybe a high pitched hum in between the bass. Right now nothing is wired up because I was afraid to blow the sub.
Ididn't have this at all with my old amp...but since it died on me, I don't have the option to hook it back up.
Old Feb 8, 2008 | 09:49 AM
rbrtech's Avatar
Default RE: B6 with a system...
WHY? Why do I know nothing of this? Ground issue for sure. It picking up interference from the ground. Your old didnt do this because of its power draw compared to the new one. Thinking that you are talking about the rockford.
Old Feb 8, 2008 | 10:11 AM
CoBra03TerminAtoR's Avatar
yepp your rcas are too close to a power source, thus givin you a really high pitched whine... step on the gas and it will more then likely move with your rpms
Old Feb 8, 2008 | 10:14 AM
LowClassA4's Avatar
You didn't hear about it because I was more concerned about the brakes, rotors, coolant
thats the same thing zb said. I need a bigger ground. I have a tiny little wire on it now. We need to start working on a box too. Where can I get the same carpet thats in my trunk at?
when do you get work done if you're lurking the forums all day?
Old Feb 8, 2008 | 11:19 AM
cbehr's Avatar
So the factory bose amp has rca jacks? I want to hook up my amp/sub but wasn't sure how it would work with the factory system.
Old Feb 8, 2008 | 04:03 PM
LowClassA4's Avatar
There are no factory RCA outputs as far as I know (I could be wrong)...
I bought this little converter from a local stereo shop. You tap into the factory amp wiring... I believe its the L Hi and Lo and R Hi and Lo. There is a DIY write up on A4mods.com...probably one in the DIY form on here too.
I have a touchscreen Clarion headunit but I didn't want to screw up the stock interior with a single din cd player. The RCA converter was ~$15. This way I didn't need to screw up the dash but could still put a sub in.
Old Feb 8, 2008 | 09:37 PM
pa4ul's Avatar
u can by a converter and tap into the one of the speakers in the back door. That will do the trick it worked on mine.
Sonita
May 3, 2015 05:58 AM
Polo2ya
Jan 10, 2014 08:33 PM
kellervernon
May 18, 2011 11:01 AM
boomshine
Oct 13, 2007 02:39 AM
headshok2002
10
May 20, 2007 01:15 AM
