boost leak?
Old Oct 20, 2009 | 03:16 PM
mtnquattro's Avatar
Default boost leak?
I have a 2003 1.8tqm, APR stage 1+. I just installed a podi boost gauge. When I get on it, the gauge is showing 25 psi +. Could this be from a boost or vacuum leak? I shouldn't be making that much boost with this setup should I? Everything sounds normal, and the car runs great.
Old Oct 20, 2009 | 04:39 PM
AutoUnionFan's Avatar
no that doesnt sound normal, you might have a problem with the wastegate or n75, talk to APR for the proper boost number
Old Oct 20, 2009 | 04:51 PM
pa4ul's Avatar
i think u should be spiking around 18 or so.
Old Oct 20, 2009 | 05:26 PM
mtnquattro's Avatar
that's sort of what i was thinking. i'm sitting at 15 inHG at idle, and it should be at 20 i think. also, i've pulled a P0229 turbo underboost code a few times after some "spirited" mountain drives. is this problem going to cause any serious damage? how can i tell whether its the n75 or the wastegate thats bad?
to4xxx
Jun 8, 2012 11:56 AM
onepoint8tee
Jun 27, 2007 04:38 PM
truckjunky87
Feb 8, 2007 12:33 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
a4bsix
Jul 6, 2006 04:28 PM
