Brake light and coolant fan
Hey everyone I知 new here but not to these cars I have a 2002 a4 b6 manual I recently did a motor swap same motor the 1.8t I just finished the swap yesterday and now I知 having a problem with my cooling fan it won稚 turn on I put a brand new thermostat in it I checked all the fuses my only issue is I知 not sure where the fuse and the relay is for the cooling fan is when I Google it keeps coming up as 219 relay Which is next to the ECU i did jump start the fan and it worked I知 not sure if someone can help me out with some kind of diagram on the plugs that plug into the Fan just to make sure things are plugged into the right place Also my left tail light fog light stays on not sure why my lights in the car is off and right when I connect the battery the lights come on really bright and my side signal will flash a couple times then stop thanks for any info that would help
