Check engine, but I have codes!
Old Dec 19, 2010 | 11:55 AM
nuba4's Avatar
Default Check engine, but I have codes!
So after a year and half of owning my A4 the light finally came on, maybe it had something to do with my WOT for a minute the other day...anyhow. Went to autozone and got the following codes: P0118 and P0030. First one seems to be an $8 ECT sensor, and the next being I think O2 bank 1 sensor 1.....heater control circuit? Not too sure about the P0030 code. Now onto the DIY. I understand these cars have multiple O2 sensors on them, dunno which faulty one I have...and as for the ECT, where is that to replace? Lastly, To make sure these are both good codes I was thinking of resetting via battery to see if they come back...this a bad idea? I've had issues in the past with this and other cars; dealing with idle speed not resetting correctly etc. thanks for any input
Old Dec 19, 2010 | 06:14 PM
nuba4's Avatar
also like to add, car is running OK; not too rich. MPG seems not effected much, and as for the temp gauge, thats working too...and not overheating etc.
Old Dec 21, 2010 | 08:46 PM
Audi Tek's Avatar
Tech Certified
B1S1 is the one right next to your air intake box.
If you pull your battery to reset you most likely will require a throttle valve adaptation
Old Jan 13, 2011 | 05:50 PM
nuba4's Avatar
Default Just got back from the stealer
So, I ran down to see what the damage would be at the stealer for these fixes, and I am a little shocked. After they verified all the codes, I was told it would be just shy of 1G to get it all fixed up, and they'd need it over night for the exhaust to cool down. I figured 500 max but I was way off. I also looked at an extended warranty to boot just for kicks, those are also insane! Powertrain alone..almost 3k, goes way up from there. Are these sensors a huge PITA to replace or relatively easy for a DIY?? O2 sensor is before the cat correct?
kashmiriomar
May 12, 2010 09:15 AM
Stevenw83
Jan 14, 2009 06:24 PM
millenia
Nov 22, 2008 01:26 PM
afstud6900
Apr 3, 2008 01:05 PM
com2255
Apr 21, 2005 08:52 PM
