Clicking noise on valve/camshaft after Timing change
I replaced the timing belt and all rollers by following the instructions in the Bentley manual on my A4 v6 3.0L. I have the timing belt on and tensioned and adjust cam timing, then removed cam lock and crankshaft lock pin. I am trying to turn the engine to check if everything is ok, by turning the crankshaft. I hear some clicking (a kind of loud) round cam/valve area on cylinder 2 or 3 only. Could that be a timing problem or something wrong with the particular valve?
Is there a way to quickly check the valve timing?
Thanks for any advices.
