clutch issue
So I just had a new clutch put in my A4 and i've noticed a big difference in where the clutch catches (almost all the way depressed) instead of halfway depressed. Also it catches much faster. Is this something that can be adjusted or something I'll just have to get used to? If it can be adjusted is this something that's adjusted easily?
RE: clutch issue
I'm pretty sure I've read herethat Audi clutches are self adjusting.. Without knowing what kinda of parts etc.. I would say that when the clutch is first breaking in you will notice much sharper and quicker engagement. It should settle back to normal, I would assume
RE: clutch issue
the clutch self adjusts, if you installed a better clutch like OFE SS or FE SS, the engagement point is much lower and cannot be changed
| All times are GMT -4. The time now is 06:15 AM. |
