AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   Code #P0421. Please help. (https://www.audiforums.com/forum/b6-models-70/code-p0421-please-help-143390/)
john@astigracing.com Dec 23, 2009 08:40 PM
Guys,
My check engine light came on; Code #P0421: Warm up catalyst below threshold (Bank 1).
What does it really mean?
Thanks,
John
Dan1969 Dec 23, 2009 11:58 PM
Your Catalitic converter took a crap...
Try checking the O2 sensor but, I'm pretty sure is the cat.
john@astigracing.com Dec 24, 2009 12:06 AM
The O2 sensors and cat were replaced at 40K miles. The car currently has 108K.
Do you really think its the cat? Is there a DIY on how to test both?
Appreciate the help.
Dan1969 Dec 24, 2009 12:26 AM
I couldn't really find any. The only way I know to test if it is the sensor is to get a new one, and those are expensive on their own. Can you see if you Cat is glowing red? if it is then is probably the cat and not the sensor and viceversa.
john@astigracing.com Dec 27, 2009 07:42 PM
Guys,
The cat should have a foul smell such as rotten egg if clogged right? Well, there is no smell at all.
Can it be the O2 sensor is the culprit?
Is Bank 1 in the passenger side?
Thanks guys!
Dan1969 Dec 28, 2009 12:18 AM
Not all the times they emit that smell, this is actually the first time of someone mentioning that. But I still wouldn't discard it, the O2 sensor is cheaper so I'd go that route too. As far as I know Bank one is the passenger side if you're in America, the driver side if in Europe or Asia.
john@astigracing.com Dec 28, 2009 12:57 AM
Thanks Dan.
john@astigracing.com Dec 29, 2009 11:40 AM
This maybe a stupid question guys, but which O2 sensor? Is it after or before catalyst?
Also, just to verify that the O2 sensor I'm going to buy is the passenger side (Bank 1).
Thanks guys,
John
Dan1969 Dec 29, 2009 12:45 PM
If I'm not mistaking this should be the one after.
john@astigracing.com Dec 29, 2009 03:04 PM
Thanks Dan.
Can someone confirm this please before I spend over a 100 bux O2 sensor.
