AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   Coolant - G12 or regular (https://www.audiforums.com/forum/b6-models-70/coolant-g12-regular-199554/)
abcxyzzz Sep 9, 2013 07:04 PM
Hi, I have a 2004 A4 Avant 3.0L Quattro, and on the weekend the Coolant signal came on. I checked the coolant and it was really low in the reservoir. I noticed that it was PINK color. Well, I have some Prestone coolant, so i mixed it 50/50 and added it to the reservoir. Is it bad to mix the two different coolants? Later i read in the manual that it "recommends" some G12 (i don't know what that is). I've always used the Prestone in my BMW, and never had a problem. Not sure if Audi requires something special or if it was wrong to mix the pink and the green Prestone coolant. Please let me know. Thank you.
pa4ul Sep 10, 2013 05:11 PM
hmm i dont think they advise to mix coolant. Something to do with it eating up the inside of the pipes most being plastic and all.. . .
gearhead77 Oct 13, 2016 11:50 PM
Yeah I read somewhere that the Audi 1.8T recommends the g12 and one reason is because of the phosphate additives in other coolant 50/50 brands. I just went out tonight to buy g12 rated coolant myself, I actually came across a G40 mix that was stated "exceeds g12 specifications" and also stated "recommended for 05 audi/vw 1.8T." Also a lot of talk on the forums about "what the car left the factory with, is what you should replace with" so another words if a certain type of oil was used to fill it at the factory new, then use the same oil, same goes with all fluids, including G12.
