AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   Coolant Line (https://www.audiforums.com/forum/b6-models-70/coolant-line-193187/)
TheMattMan Mar 9, 2013 09:06 AM
Coolant Line
1 Attachment(s)
Hello
I have a coolant line that goes from the back of the tank down to the engine and where it connects to the engine it has a small amount of white where coolant has burned. It will occasionally leave a very small puddle of coolant after a long drive. Where this line enters the engine, is there a sensor that it goes on or a gasket/oring that could be leaking? I have included a link to a picture of what I am talking about.
Matt
Attachment 27115
pa4ul Mar 11, 2013 05:13 PM
:: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
TheMattMan Mar 11, 2013 06:23 PM
I thought the coolant sensor was more on the other side of the engine? This is on the driver side. I am going to check and replace the temp sensor also because I am occasionally/recently getting a leak that is dripping on the exhaust on that side and evaporating/smoking. It's not leaking enough to need to refill the coolant yet, so I know its a small leak, and the temp guage seems to be operating correctly and the engine isn't running hot and doesn't feel hot after driving for a while.
Just bought the car used a few months ago, and have been chasing down all the little things like this, while learning about Audi.
pa4ul Mar 13, 2013 06:25 PM
there are two coolant sensors. ONe near the intercooler coming out of the radiator. U can use that one to easily flush the system if u ever need be. The other is a pain to get too and tends to leak cuz the oring gets worn. Also a spot that leaks in that area is the coolant flange which will leak onto the tranny and exaust. U might see puffs of smoke from the firewall while at idle.
TheMattMan Mar 15, 2013 10:05 AM
Does the 3.0 V6 have the same flange on the back? The drawing I recently found, which I will include, shows the coolant temp gauge sensor that usually attaches to the flange is attached to a rear coolant pipe. I have found the hose that I included on the picture from the original post, which shows a hose, connecting piece and a seal. I haven't located where to find the exact part yet and I need to see if its the hose or the seal under the connecting piece.
[IMG]http://i29.photobucket.com/albums/c2...olantPipes.jpg[/IMG]
I also get a small drip that burns off around where the coolant sensor o-ring exists or the o-ring labeled 7 in the rear coolant pipe. I am going to try to locate it this weekend.
