Cooling Issues
Old Apr 5, 2010 | 06:57 PM
dafowler88's Avatar
Angry Cooling Issues
Hey Guys,
I'm having some trouble with my car, but it's sporadic. Sometimes it runs fine and other times it will get hot. Not over heating but above where it's supposed to be. I have no CEL. I have noticed one change, (and this is what I think is the problem) that the fans do not come on typically like they used to. Sometimes they'll come on for a second or so, and then shut back off..and this is when the engine is already hot. Then they'll come back on after about 10 seconds, etc. Any idea what could be causing this? Thanks for any advice you can give me.
Darren
Old Apr 5, 2010 | 08:54 PM
Dan1969's Avatar
Run a scanner through it, or a VAGcom, your fan control unit went out I believe, this will tell you on the code that it returns.
Old Apr 5, 2010 | 09:05 PM
dafowler88's Avatar
Wow, I hope not! $270 part!!! Ahhh!!! I may have to take it to Autozone, I don't have a code scanner. But I will let you know, if I get any, what they are.
Old Apr 5, 2010 | 09:33 PM
Dan1969's Avatar
Yeah you're looking at a bit of money. I believe someone over in Audizine has one for sale if you need it.
Old Apr 5, 2010 | 11:50 PM
dafowler88's Avatar
Thumbs up Sweet!
Thanks a lot bro, just found it and I'm contacting him now. Good lookin out.
Old Apr 6, 2010 | 08:46 AM
JoeD1346's Avatar
If you are comfortable splicing wires, replacing the coolant fan control module is relatively easy.
Old Apr 7, 2010 | 04:36 PM
Myst420's Avatar
I replaced mine about a year ago, and it took me about 10 minutes. Its bolted to the top of the radiator, so you can access it easily.
Old Apr 16, 2010 | 07:44 PM
dafowler88's Avatar
Default Same problems
Replaced the control module and still having the problem. What other sort of thing could it be? Any ideas? Thanks again.
Old Apr 16, 2010 | 08:34 PM
Dan1969's Avatar
hmmm, I take that you never ran the code... There's two things that cause this, it could be your thermostat or the "other" coolant temperature sensor, run the codes before you waste any more money.
Old Apr 18, 2010 | 10:28 PM
dafowler88's Avatar
Yea, it didn't return any codes. Thanks for the advice tho.
