AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   Current draw when key is off (https://www.audiforums.com/forum/b6-models-70/current-draw-when-key-off-188193/)
jc_audi_a4_02 Oct 12, 2012 02:19 AM
I parked my car for a few weeks and when I came back to it, the battery was dead. I've since fully charged the battery several times (removed from the car), but I can't leave it hooked up for any length of time or it gets too discharged. Even after I fully charge the battery (removed from the car), then start the car and run it for ten minutes, if I shut it off, I will have trouble immediately restarting.
So I've been trying to figure out if something is drawing excess current when the car is off. I hooked everything up, put my DC ammeter inline, locked and armed the car, and waited 5 minutes. The current draw went down to about 120mA. Then I did the same test, but with the alarm system fuse out. The current draw was down at 80-90mA after 5 minutes.
This still seems too high. My theory is that it has been doing this for a while and when I let the car sit for a few weeks, it was the last straw for the battery. I'm going to replace the battery (not even 2.5 years old yet) and I think that should keep me going if I don't let the car sit for too long. But I think I still have a current draw problem. I'm going to systematically pull fuses and relays and see what happens, but I was hoping someone has something to add.
Anyone agree? Disagree? Advice?
Thanks guys.
z28pete Oct 12, 2012 10:59 AM
That is a good way to do it. Remember that there is a certain amount of current flowing all the time which is used to keep the various memory settings happy
pa4ul Oct 12, 2012 01:30 PM
check your tail bulbs and see if any are very dim but lit. I had a problem once with my body control module going out. It was sending a small amount of juice to the tail lights keeping them on all day and night. Ended up replacing the module.
jc_audi_a4_02 Nov 3, 2012 06:42 PM
Well, I never really ended up finding an electrical problem. I took my battery back to get a partial warranty replacement. They gave it a good charge and put it on their tester and it came out as weak. So I'm up and running with a new battery.
