DMIC VS FMIC
Old Feb 20, 2008 | 09:57 AM
Supaant06's Avatar
Default DMIC VS FMIC
I was looking into doing an intercooler mod when I heard about these two I am just wondering which is better... FMIC or DMIC. I no they are doing DMIC out in the UK standard and it is supposed to be way easier to install than FMIC, but I heard FMIC is better. So, any advice on the pros and cons on either is much obliged. Thanks.
Old Feb 20, 2008 | 10:09 AM
turbo kraut's Avatar
Tech Guru
Default RE: DMIC VS FMIC
if you can get alot better flowing smic then go that way if you are going to stay stock.... to semi stock... no heat soak blah blah blah
but if you are going to want to upgrade and want a more menacing look fmic
Old Feb 20, 2008 | 11:41 AM
Papachristou's Avatar
if you are not going above k04, i would get the apikol SMIC upgrade seen here, i would stay away from the DSMIC since several people have had the plastic end tanks on them blow under higher PSIs but then again plenty of people run them...
http://www.audizine.com/forum/showth...ht=apikol+SMIC
FMIC will look better (in my humble opinion) and keep your IATs more inline with ambient temps... ractec and ER sport are good options 380 and 351 cu in respectively...
Old Feb 20, 2008 | 02:42 PM
cincyTT's Avatar
I'm make believe
Dual smics is far less efficient than a fmic. It has to through 2 inlets and outlets than just one long one. THis will slow down the air velocity. Not to mention you can fit a fmic to fit any power level where a smic(s) is limited due to more space constrants.
So_NAudi
Jun 12, 2008 02:25 PM
DurTTy
Aug 7, 2007 12:20 PM
6g72tt
Apr 30, 2007 10:28 AM
sooks
Apr 2, 2007 01:48 AM
tatman9999
Aug 29, 2006 03:12 AM
