Electrical problems???? Please help!
Old Dec 28, 2013 | 01:56 PM
christophergreen123's Avatar
Default Electrical problems???? Please help!
Hi, I am new to the forum and really need help! I am having problems with my a4 b6 2002 turn signals, wipers and horn not working, also when parked up for the night something draining the battery. I also have no power windows.. changed my steering control module today with no joy.. still have same problem???
Thanks in advance
Old Dec 29, 2013 | 08:52 AM
CryptoStorm's Avatar
Are you blowing fuses?
Old Dec 30, 2013 | 07:32 AM
Thought that but checked them a number of times and seem fine?
Old Dec 30, 2013 | 06:19 PM
M5S5's Avatar
Tech Certified
Is the carpet wet underneath the drivers seat?
Old Dec 30, 2013 | 06:55 PM
markymarc's Avatar
If your carpet isn't wet under driver's seat....I'd say it's a bad load reduction relay maybe?..... It's the one under the dash on Driver's side I believe....See attached pic (for a B5, but my B6 has relays under the panel as well).
Attached Thumbnails Electrical problems???? Please help!-2010-04-08_165342_b5a4relaypanel.jpg
Old Jan 1, 2014 | 11:20 AM
Carpet dry thankfully... Get checking relays thanks guys
Old Jan 14, 2014 | 02:03 AM
AshyndaShengying's Avatar
did u check the wires that go to ur door, somehow from closing door the wires don't tuck good and rip, i had that problem. see if this helps
Old Jan 14, 2014 | 05:27 PM
pa4ul's Avatar
sounds like your electronics control module. . . HAve u inspected all your lights when the car is off to make sure non of them stay lit even if they are very very dim.
Mercy404
May 2, 2015 09:22 PM
Jimbezy
Mar 24, 2009 08:23 PM
kraiv
Jun 28, 2008 03:48 PM
02A418T
May 1, 2007 10:57 PM
baba
Mar 12, 2007 03:02 PM
