Engine Overheat Problem!!
Old Mar 26, 2008 | 03:16 PM
sa3dos's Avatar
Default Engine Overheat Problem!!
Hello folks,
i am a newbie, just bought Audi A4 B6 (1.8T Quattro) yesterday with 60,500 miles on it
I tested the car, no mechanical problems at all. A problem came up yesterday,
The car engine overheates when its at rest for 20-30 minutes and I get the Coolant message in dash
If I rev the engine, the temperature doesn't go down ( I figured its not a thermostat problem). Looking in the engine bay, none of the two fans are working!!
I tried to locate the Fusebox to check if there exist a fuse for these cooling fans,, I couldnt find the FuseBox!! Where did the germans hide it? lol
What are your suggestions to diagnose the problems folks?
Old Mar 26, 2008 | 04:04 PM
audi4a's Avatar
Default RE: Engine Overheat Problem!!
I am positivie it is your fan control module; it is no good and nneds to be replaced. It is a located in front of your alternator mounted right below the red engine warning sticker. This cost about $650.00 at the dealer plus labor. These cars are notorious for this problem.
Old Mar 26, 2008 | 06:17 PM
sa3dos's Avatar
Is this the part that I need ?
AUDI A4 2002 - 2006 Fan control relay 8E0 959 501 R01
http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWD1V
Old Mar 27, 2008 | 01:07 PM
sa3dos's Avatar
Is there a way to dignose the problem before I go ahead and buy a fan control relay? i.e. is there a fuse for it in the fusebox?
Any suggestions ?
Old Mar 28, 2008 | 12:22 AM
MikenMel's Avatar
Could be a water pump also. Just had ours go out and the motor got hot, especially when standing still. Had the coolant warning indicator on the dash too. Dealer charged $800.00 to fix it Original pump is a poor metal on plastic design that will seperate from the shaft. New all metal one is better.
jaesae84
Aug 2, 2012 12:20 AM
chromatin
Nov 17, 2008 10:31 AM
Adelie
Jul 23, 2007 01:38 PM
detroit_basketball
Jul 2, 2007 01:14 PM
paultemp1
Nov 28, 2006 12:02 AM
