EPC light- help
Old May 6, 2013 | 05:42 PM
irishaudi's Avatar
Default EPC light- help
2002 a4 1.8t, battery recently died due to lights left on.
tried to bumpstart (roll it down hill, cars a stick),failed so got a friend to jump it.
car started right up and runs like a champ again however the epc light is now constantly on. car is not in limp mode, and runs fine, no check engine lights.
any help? new battery perhaps, a relay? checked fuse 29 shes not blown
Old May 6, 2013 | 05:53 PM
CryptoStorm's Avatar
Just like with a check engine light, you just have to go get the codes read.. Its impossible to know why itson until you do..
Old May 6, 2013 | 06:26 PM
pa4ul's Avatar
Guy really stop commenting on articles unless you have something valid to offer. The epc light will go off once u drive around a bit. Thats normal when the car battery dies. Just drive around a bit it will turn off.
Old May 6, 2013 | 08:41 PM
irishaudi's Avatar
been on for over a week, racked up a almost 200 miles with it on
Old May 7, 2013 | 09:47 AM
Not all EPC lights will just "go off once you drive it a bit". ??!! Cause your "solution" was SO insightful...
There are lots of reasons for a EPC light.. Some of them minor (or flukes) and will go away.. The only way to figure out what the light is pertaining to is to go get the code..
Old May 7, 2013 | 12:32 PM
irishaudi's Avatar
Ok so i hooked up my obdii scanner i purchased from autozone( crappy), and got code p0688- engine control relay, is this what could be causing the epc, perhaps i damaged the relay when jump starting? Have no mil on just epc, but car runs perfect
Old May 7, 2013 | 08:02 PM
That code could mean many things..
It could be nothing as pa4ul suggested.. I would first give your battery a good charge with a real battery charger.
Old May 7, 2013 | 09:11 PM
irishaudi's Avatar
Ok cool nay also see about load testing battery, its old and may be ready to die
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
