cranks,but will not start.
I have a 2002 Audi a4 b6 that will not start i replaced the fuel pump and the fuel filter. i also checked the fuel injectors an cleaned them they all work and theres is fuel in the fuel rail and there is pressure. As of right now i turn the key a few time to try and start it and it goes completely dead like if there is not battery in the car. I checked the fuse and there good i changed the fuel pump relay under the steering wheel also. I dont know why my car keeps wanting to die like if there is no battery in the car. Im thinking that i might have a bad ground some and also when i spray starting fluid into the throttle body and it starts only when starting fluid is being sprayed so im thinking that i'm not getting power the fuel injectors so im stuck on what to do next right now im replacing the wiring harness to the fuel injectors the wires are exposed so there in bad shape im hoping this will get it started.
