EPC Light and stalling
  #41
Old 06-30-2017, 03:04 PM
Wam
Wam is offline
I had similar issue with my 2007 A4 Cab, EPC light coming on intermittently but CEL constantly on. Got it checked by Audi dealer. Turned out couple of power relays were burnt. Replaced those and now all Ok.
  #42
Old 09-21-2017, 10:36 AM
Mark Junkin's Avatar
Hi All,
I need some help. I have a 2009 Audi S5 and the EPC and check engine light keeps coming on. I have taken the car to the deal and have had them scan the car for faults. I keep getting low fuel pressure. I have changed both high pressure fuel pumps, both low & high pressure fuel sensors and still am having the same issue.
I did change cylinder number 4 fuel injector due to it being stuck open and causing a miss fire. Any toughts or suggestions would be welcome. Audi's diagnosis was to change everything. They did not know what was causing the issue.
Thanks for your help!
  #43
Old 12-26-2017, 10:24 PM
Need help have a 2006 Audi A3 had a coolant hose split and replaced it after I filled it back up with coolant started the car and ecp light came on,tried to drive to see if code would go away around 2-3,000 rpm it sputtered and had no power ..it idles below 1,000 rpm
  #44
Old 03-30-2019, 04:32 PM
Default A4 B6 3.0 EPC and crankshaft speed sensor
Greetings all. Just wanted to chime in. I just replaced my crankshaft speed sensor in my 3.0. Sensor is the same, but is in a different location compared to 1.8t. I had to pull the sensor from underneath. I did remove the heat shield guarding the sensor. By removing two Allen head screws (1 was 5mm and one was 4mm). My sensor was secured by a 1 hex head bolt (10mm). From the top, I found the toughest part was unbuttoning and buttoning the heat shield wrapping the sensor cables).
Because of time constraints, I went with a Bosch part from advanced auto (it was in stock) as I didn’t have to time order OEM.
Anyways, no start up issues so far.
Hope this is helpful to someone else with the 3.0.
2003 A4 Quattro Sedan. 3.0. 196,xxx miles and counting.
  #45
Old 04-02-2019, 08:30 AM
Red face
Originally Posted by RyanThompson View Post
Hi! According to me, https://dsrleasing.com/car-listings/...-lease-409-mo/ such a great deal and the car is looking awesome.
Yes, DSRleasing is really a good company and they provide always great deals. I recently bought a BMW check my deal plan https://dsrleasing.com/car-listings/...-lease-469-mo/
  #46
Old 04-03-2019, 11:24 PM
Carlos Martin's Avatar
Recently my friend lease Audi A7 from DSRleasing, I was with him from start to end. DSR Leasing, especially Johnathan, is the real deal! I've purchased and leased cars many times before and I am very confident in my negotiating skills at the dealerships. However, when I was having a hard time locating the exact color and the trim level that I was looking for, I was referred to Jonathan by one of my friends. I am so glad that I found Jonathan! He got me the car in my exact spec at a price that I could only dream of. And the best part was that the whole process was so easy! He even delivered my new car to my house! Top notch service from a top-notch guy. I will be using DSR Leasing for all of my future car purchases.
nkosijames1994
04-10-2014 02:11 AM
urizen666
02-02-2014 01:18 AM
DanaNicole
08-24-2012 07:18 PM
Steven Huff
02-03-2012 09:14 PM
Nicks A4
08-28-2007 07:23 PM
Quick Reply: EPC Light and stalling
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
