Error Code Too Lean Fuel Filter?
Old Feb 5, 2009 | 05:53 PM
Skiguy's Avatar
Default Error Code Too Lean Fuel Filter?
I travel the same route to work each day. On section, I travel up a steep hill in 5th with a speed of about 55. As soon as I hit the hill, the CEL light comes on with "enigne too lean, bank 1". I reset and I'm fine till I hit the hill section again.
Were should I look to fix?
Someone suggested a boost leak or possibly a fuel filter.
Can is an 02 1.8 with APR Stage 1 plus, 386 injectors, K & N filter with 84K miles.
Any thoughts or suggestions appreciated.
J
Old Feb 5, 2009 | 06:35 PM
shane.trammell's Avatar
check vacuum lines and check valves. i got that one, the line at the front inside of the IM was bad.
Old Feb 21, 2009 | 02:46 AM
treelimb's Avatar
What is the trouble code? Do you have P0171? Broken vacuum line or check valve will cause lean running condition and idle problem. In your case, i think you have MAF sensor problem. Also get rid of the K&N filter after installing a new MAF sensor.
Old Feb 21, 2009 | 09:09 PM
wolfdog's Avatar
Clean the MAF. I've run for 30k miles so far on K&N panel without issue. As long as you don't over oil the thing you shouldn't screw your MAF.
Old Feb 21, 2009 | 10:51 PM
wrecklessA4's Avatar
I had the same issue, and it cost me $300 bucks to find out it was just a simple $6.00 fix. My issue was the MAF sensor was dirty, I'm guessing oil from my K&N filter got it dirty or something, i bought some MAF sensor cleaner from autozone, cleaned mine up. and wa la problem solved. try that before you go off spending all kinds of cash for something you dont need. hope this helps.
DCAV8R
Jan 23, 2023 06:33 AM
joshlowe
Jan 23, 2014 01:41 PM
daveck2
Sep 24, 2009 05:40 PM
jacobennis
Jan 12, 2009 10:27 PM
jhsoccerodp
Sep 22, 2008 07:54 PM
