esp
Old Feb 11, 2008 | 09:57 PM
bronxblaza117's Avatar
Default RE: esp
ORIGINAL: Crunk
How do you know if the ESP button works....... I can't tell if mine is on or off. The button does nothing???? No lights, no indication of whether it's on or off. Think mine's Broke......LOL
lol, when you press the esp button a warning light lights up in the gauge cluster
Old Feb 11, 2008 | 10:50 PM
Sherman Banks's Avatar
Default RE: esp
Why is it you need to fix your ABS right away anyways? I wouldn't be worried about it unless you drive fast and ride people's rear ends.
Old Feb 12, 2008 | 01:27 AM
32_d3gr33s's Avatar
Default RE: esp
I have the same problem in my car. My mechanic told me it came back with two codes; one was a brake controller (if it wasn't working my brake lights wouldn't work properly) or some camber-tilt-sensor something or other(not exactly sure what he said it was. I noticed my light comes on if I turn too sharp when its real slippery on my wheels let loose.
Old Feb 12, 2008 | 01:48 AM
silveraudib6's Avatar
Default RE: esp
lol thats funny but no i only drive like that if i have to
ORIGINAL: Sherman Banks
Old Feb 12, 2008 | 01:50 AM
Default RE: esp
ORIGINAL: 32_d3gr33s
so did you ever get it fixed? i dont really know what iam doing for it to come on i haven t really noticed it yet.
Old Feb 12, 2008 | 08:58 AM
amiller86's Avatar
Default RE: esp
I pretty sure it's supposed to flash when you spin your wheels..and you're loosing traction because you're makingreally sharp turns when it's really slippery.
Old Feb 12, 2008 | 10:49 AM
Crunk's Avatar
Default RE: esp
ORIGINAL: bronxblaza117
ORIGINAL: Crunk
I don't have any lights on my display......I have never seen anything come up on my display!!
Old Feb 13, 2008 | 10:32 AM
  #18
32_d3gr33s's Avatar
Default RE: esp
ORIGINAL: amiller86
I understand that... I'm saying thats when my fails to continue working. It will blink while I'm slipping, then about 30 seconds later the light will come on and stay on and my traction control stops working. I haven't got it fixed yet, because I'm not too worried about it. I actually like driving without it on better. You can fishtail it and whip shitties a lot better!!!
Old Feb 13, 2008 | 11:06 AM
  #19
mudwalker's Avatar
Default RE: esp
It's suprising you folks don't know more about your Electronic Stability Program. It's a wonderful system that controls both individual wheel braking and more importantly throttle position. Wheel sensors (ABS) signal computer to cut throttle and send ABS braking to wheel or wheelsthat has lost grip.
From the manufacturer:
"The program uses the anti-lock braking system (ABS), electronic brake-force distribution (EBD), the electronic differential lock (EDL) and the traction control (ASR) system, and is permanently active."
The ESP button on the dash changes the program to allowfor less intrusion of the system allowing the driver more freedom (slippage).
When a wheel loses traction or the car starts to slide, the dash light (orange wheel) flashes. When the ESP button is engaged the same light illuminates and stays on until the button is pushed again or the car is turned off at which time the system is reset.
Old Feb 13, 2008 | 11:12 AM
  #20
amiller86's Avatar
Default RE: esp
ORIGINAL: mudwalker
Actually I think we covered that..And I think that the questions were why the program wasn't workig, not what it was.
