Fog light mod (parking/fogs only)
Old Aug 4, 2009 | 09:38 PM
swann17's Avatar
Default Fog light mod (parking/fogs only)
Hello everyone,
I have been searching to see if it is possible to have your parking lights on AND fog lights on at the same time. I have a 2005 A4 (b6 model) and have not found any threads for this model car. In my situation, right now fogs only come on when the headlights are on. After searching everywhere i have found instructions on this mod, however, only for B5 and prior model A4's. From what i have found, there are 2 mods (at least for the B5 model and prior).
1) splice two wires that lead to the light switch but doing so will turn the fog lights on every time the parking lights are on.
OR
2) buy fuse taps and tap into 2 specific fuse sockets in the fuse box. This procedure allows you to turn on the parking lights and fog lights (when the switch is pulled out) but not the headlights.
I would prefer to do the 'fuse tap' mod bc it is easily reversable and doesn't require splicing any wires in the car. When i looked in my fuse box tho, i couldn't find a fuse for the healights and the front fog light fuse location did not have a fuse in it and everything works. Kinda weird to me but whatever. If anyone knows about this and can help me out that would be helpful. Instructions are great too In the meantime i will keep searching.
Best regards~
Old Aug 5, 2009 | 12:46 PM
pa4ul's Avatar
http://www.audizine.com/forum/showthread.php?t=188467
keep in mind that u might need to vag your car to world mode or canada as us models wont run fogs without headlights on unless you vag it.
Old Aug 5, 2009 | 01:05 PM
Audiman08's Avatar
http://www.audizine.com/forum/showth...ght=ebay+cable
some codes are at the bottom. just set mine up yesterday
Old Aug 5, 2009 | 10:10 PM
swann17's Avatar
I know i have seen instructions for this mod before but i couldn't find any for my model car. This is going to help me out big time. Thanks to the both of you guys.
jcA4Quattro
Jan 5, 2012 08:06 PM
jlight113
May 27, 2010 11:52 AM
myaktine
Aug 14, 2007 04:58 AM
crazygnerd
Nov 6, 2006 12:48 AM
haveaseat
Jan 20, 2006 02:22 AM
