fog lights not working
Old Feb 7, 2009 | 10:52 AM
rhumen's Avatar
Exclamation fog lights not working
i did a full search on this website prior to this posting, so i am sorry if the answer has been previously posted.
i just bought an 02 a4 1.8t... it has fogs equipped but when i pull the switch, they do not turn on, nor does the rear fog, and there are no light warnings.
i checked fuses, but there is nothing noted on the fuse panel. i'm new to audi's, and i am just curious where i need to look for the problem.
do i replace a fuse?
do i replace bulbs?
is there a more sinister culprit?
Old Feb 7, 2009 | 11:04 AM
shane.trammell's Avatar
if it's not a fuse it's likely the headlight ****/switch.
Old Feb 10, 2009 | 12:54 PM
rhumen's Avatar
i pulled the switch and verified the connection was secure. I guess I will just have to go find someone with an operational switch and swap them to see if that's the issue before i buy a brand new one.
Old Feb 10, 2009 | 01:16 PM
Myst420's Avatar
Just a question...but do you have the headlights on while you're trying to turn on the fog lights?
Old Feb 10, 2009 | 01:22 PM
Good thought, I forget that the **** will pull even with the lights off.
Old Feb 10, 2009 | 07:14 PM
krystallbluea4's Avatar
Yes, lows must be on. Foglights will not operate without the lowbeams. They turn off again if you switch to high-beams(even though low's stay on). You have to "vag" (search ross-tech vag-com)the central convenience module to RDW as well as splice pins #1 and #2 on the headlight switch for fogs to operate independently of the low-beams. Even with that done the DRL's still need to be switched to the on position.
Also should be mentioned that when you pull switch out two-positions(all the way out) that turns on your rear fog light. There is only one, apparently so its not confused with brake lights. It's on the driver's side. It looks ridiculous leave it off.
Here's my car vag'd and spliced:
HID High/Low/Fog:
https://www.audiforums.com/forum/alb...pictureid=3321
HID Low/Fog:
https://www.audiforums.com/forum/alb...pictureid=3323
HID Fog/g-dam DRL's:
https://www.audiforums.com/forum/alb...pictureid=3322
Old Feb 11, 2009 | 02:01 PM
rhumen's Avatar
yes, i have the lights on and there is still no fog lights, front or rear.
note: when i have the lights on and pull the switch out one click - no fog lights and no indicator lights... then i pull the switch for the second click (rear fogs) - no fog lights, but the rear indicator on the switch **** lights up...
regardless, i have no operational fogs front or rear and no lights out warning.
this is weird.
Old Feb 11, 2009 | 02:08 PM
Myst420's Avatar
That sounds like a bad switch to me.
He may not need to splice the wires since he has an 02. From some research, I've discovered that for some 02 models, you only have to Vag-Com.
Old Feb 11, 2009 | 02:13 PM
Ahh soo! You are correct myst420! My bad. Im going to side with the switch being faulty as well. For a used switch try www.shokan.com. Good luck!
Old Feb 11, 2009 | 08:31 PM
rhumen's Avatar
thank you for the advice. i wish i knew someone around here that would let me borrow their working switch for 2 minutes... i'll look around and see what I can find.
Expplucky
Apr 24, 2013 03:13 PM
konboy22
Jun 9, 2011 01:01 PM
CLX
Jan 7, 2008 03:59 AM
krnboynemesis
Sep 1, 2007 11:11 PM
a4quattro
Nov 26, 2005 02:51 PM
