forge splitter leaking oil!?!?!??!?
Old Mar 15, 2008 | 02:37 PM
iamdaone187's Avatar
Default forge splitter leaking oil!?!?!??!?
just finished cleaning my engine...and while i was down there in the air box side i noticed that there was some like muddy sludgie build up on the DV where it blows out the air but it didnt smell like motor oil..anyone got any ideas or is it just like dirt build up down there??? thanx
Old Mar 15, 2008 | 02:56 PM
cincyTT's Avatar
I'm make believe
Default RE: forge splitter leaking oil!?!?!??!?
It is oil. It is the blow by from the engine. If you want to prevent this, you need a catch can. If it continues, you will have a pool of oil in the ic and have crusted oil in the TB which can cause more problems
Old Mar 15, 2008 | 02:59 PM
oh ok.. sorry but what do u mean by IC & TB???
Old Mar 15, 2008 | 03:05 PM
cincyTT's Avatar
I'm make believe
ic - intercooler
TB - throttle body.
Its nothing that throttle body cleaner can fix in seconds
Old Mar 15, 2008 | 03:11 PM
oh ok...so should i just put the cap on and run it in stealth mode then?
Old Mar 15, 2008 | 03:20 PM
cincyTT's Avatar
I'm make believe
WOnt change the fact you have blow by going into the intake. The only way you will stop that is with a catch can. They are simple to install and will keep everything free of oil. Just keep the valve the way you have it.
Old Mar 15, 2008 | 04:13 PM
oh ok...where can i get one of these "Catch Cans"????
Old Mar 15, 2008 | 04:16 PM
cincyTT's Avatar
I'm make believe
summit, jegs, ebay, basically any online parts stores. If you go with an ebay can, you will need to fill it with steel wool.
Old Mar 15, 2008 | 04:24 PM
alright thanx man!!!!
SunnyShaida
Dec 5, 2008 05:35 PM
czabelin
Aug 30, 2008 04:04 PM
APRaudiA4
Apr 30, 2008 06:41 PM
vegastt
Sep 4, 2007 12:18 AM
Mya4T
Apr 25, 2007 02:19 AM
