Fuel Gauge is Dead
Old Dec 1, 2008 | 01:08 AM
jag0214's Avatar
Default Fuel Gauge is Dead
My fuel gauge recently died and I am considering having this fixed. I have limited knowledge here, but suspect that it is the fuel sending unit. My question is: Will this fix require replacing the fuel pump on the 2002 A4 model or is it a stand-alone part? Also, would anyone like to speculate on what this might cost at the dealership?
Thanks in advance.
Old Dec 1, 2008 | 08:16 AM
Myst420's Avatar
Are you sure its bad? My gauge stopped working in my car one day right after filling it up (it said it was on E after I put 15 gallons in it.) All I ended up doing was disconnecting the battery for a minute and then when the ecu reset, everything was good to go.
Old Dec 3, 2008 | 11:31 PM
jag0214's Avatar
Thanks a lot for the tip! I will give that a try.
Old Dec 4, 2008 | 12:08 AM
SunnyShaida's Avatar
I don't know about 2002 but I do kno there is a recall on the fuel pump for 2003 so you should look into that
Old Dec 9, 2008 | 12:58 AM
jag0214's Avatar
Well, I disconnected the battery and it worked, but strangely, not immediately. I filled up the tank a few days later and it kicked in again. I'll look into the recall too. Thanks!
Aprentice
Jul 11, 2012 05:28 AM
boostedZJH
Sep 13, 2011 01:18 AM
ruckus1027
May 27, 2011 06:37 PM
mnorm757
B7 Models
May 11, 2011 04:00 PM
popone913
Jul 20, 2009 11:28 AM
