Need an opinion on this cel
Hey la gang,
I've been driving around with a cel for the past 5 days with absolutely nothing wrong except this.... I thought I'd clean out the MAF and see if this would turn off the Check engine light and I noticed that the Small hose that is "supposed to be" attached to the breather was disconnected. I reattached it but I'm wondering now if this is what triggered the CEL. Would anyone know the answer to this question? Cheers and Thanks :) |
RE: Had a CEL and nothing wrong except this....
Try vagging it, it might be something completely different than your maf, etc...
Yeah well, here in Canada they charge you to Vag it so I thought I'd ask here first.
Maybe there is some dirt or you didnt connect your MAF properly. Maybe it has nothing to do with the MAF at all.
It probably has nothing to do with the MAF because I thoroughly cleaned it and gently placed it back in. I also checked the gas cap and it's on tight. Other than that I can only reason that the snall hose coming out of the filter box triggered a sensor somewhere.... I found a buddy of mine in Ottawa who can vag it... We'll see what the codes say this afternoon ;)
Thanks for the help :) |
Well folks,
I had the car scanned and the codes were cleared last week BUT, CEL still came on so heres the result of the scan that was done last week. would anyone be able to tell me what couls be triggering the CEL???? - VCDS Version: Release 805.0 Data version: 20080625 Wednesday,23,July,2008,18:45:10:25382 Chassis Type: 8E - Audi A4 B6/B7 Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 69 75 76 77 Mileage: 128020km/79547miles - Address 01: Engine Labels: 06B-909-518-AMB.lbl Part No SW: 8E0 909 518 F HW: 8E0 909 018 Component: 1.8L R4/5VT G 0001 Coding: 0016701 Shop #: WSC 79410 154 402950 4 Faults Found: 16712 - Knock Sensor 1 (G61): Signal too High P0328 - 001 - Upper Limit Exceeded - Intermittent 16487 - Mass Air Flow Sensor (G70): Signal too High P0103 - 001 - Upper Limit Exceeded - Intermittent 17544 - Fuel Trim: Bank 1 (Add): System too Lean P1136 - 001 - Upper Limit Exceeded - MIL ON 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 002 - Lower Limit Exceeded - Intermittent Readiness: 0000 0000 - Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 A Component: ABS/ESP allrad 1726 Coding: 04275 Shop #: WSC 06435 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 35-10 - - - Intermittent - Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 G Component: A4 Klimaautomat 0712 Coding: 00000 Shop #: WSC 63351 2 Faults Found: 01274 - Air Flow Flap Positioning Motor (V71) 41-10 - Blocked or No Voltage - Intermittent 01592 - Air Quality Sensor (G238) 30-10 - Open or Short to Plus - Intermittent - Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 E Component: int. Lastmodul KAN 0305 Coding: 00004 Shop #: WSC 63351 1 Fault Found: 01794 - Control Module - Incorrect Chassis (VIN) Number 35-00 - - - Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 A Component: Airbag 8.4E 3000 Coding: 0010607 Shop #: WSC 63351 000 00000 No fault code found. - Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 L Component: Lenksáulenmodul 0308 Coding: 00041 Shop #: WSC 63351 No fault code found. - Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 900 H Component: KOMBI+WEGFAHRS. RB4 D25 Coding: 03300 Shop #: WSC 32390 AUZ6Z0A0281947 No fault code found. - Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 T Component: Komfortgerát T5B 0617 Coding: 11852 Shop #: WSC 63351 6 Faults Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00962 - Alarm via. Tilt Sensor 35-00 - - 01368 - Alarm triggered by Luggage Compartment Switch 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch; Passenger Side 35-00 - - - Address 56: Radio Labels: None Part No: 8E0 035 195 A Component: symphony II NP2 0007 Coding: 00001 Shop #: WSC 00001 No fault code found. End - |
bump anyone?
2 Attachment(s)
Ok so I went and had another look under the hood.... Two things
1. I did some research and found out that I may need to tighten the knock sensor soooo, I went looking for it. The knock sensor is not where everyone says it is which is on or under the intake manifold. I looked at some on the forum of the IM and it seems that on the B5 the manifold has a fews things connected to it https://www.audiforums.com/forceddow...ile=0%3B390507 See also http://www.audiworld.com/tech/eng89.shtml where they can be easily accessed. Soo I took a look at my B6 and this is what I realized. Attachment 53900 1. There are no connections at the top of the IM like in the previous pic. On my B6 (first of the 02's) it seems that the only thing connected to the manifold where it can be easily accessed is a vacuum line. I think that the KS is under the manifold and connected directly to the block. If it is, it's VERY hard to get at without having to remove a bunch of things. Not sure about this. Can anyone confirm with a pic please. 2. When I took a closer look at everything I noticed that the vacuum line mentioned above was broken at the point where it connected to the IM so I cut the end off and refitted it onto the IM..... Can ayone tell me if this once leaky vac line could have been what triggerred all these faults and finally the CEL??? Attachment 53901 I hope someone can help.... I am at a bit of a loss here. :( |
Update
A few days ago I replaced the worn out vac line with a new one and cleared the CEL.. It was an EXTREMELY EASY DIY and since then the CEL has not come back I think that not having the proper pressure in the engine eventually led to offsetting other components of the engine thereby triggering the CEL. God I'm glad I took the time and effort to research this because I can only imagine what the dealership or even another mechanic would have told me to rack up the cost. All in all it only cost me 14 dollars in parts :)
Cheers |
So, NO ONE HAS AN OPINION ON THIS????
come on guys!!! SOMEONE must have experienced this at one point. |
