hazard lights dont blink when i hit lock button
Old Jan 3, 2011 | 10:06 PM
muurai's Avatar
Default hazard lights dont blink when i hit lock button
but it turns on when i unlock?
Old Jan 4, 2011 | 01:53 AM
32_d3gr33s's Avatar
when you hit the lock button, is everything actually locking? try locking and unlocking once with the key. and make sure all your doors/trunk/hood are closed
Old Jan 5, 2011 | 11:54 AM
shane.trammell's Avatar
is there a chirp? if not, like that guy said^, something is not closed, or not registering as closed.
Old Jan 8, 2011 | 04:29 AM
muurai's Avatar
i never thought about it but my hood sensor is bad and it shows that the hood is on and thats most likely whats causing it. now how would i fic the hood sensor? a whole new hood latch ?
Old Jan 8, 2011 | 07:36 AM
Mike-2ptzero's Avatar
Might need a whole new latch. Did you try unplugging the sensor and see if it then shows the hood is closed and the alarm arms?
Old Jan 8, 2011 | 09:39 AM
and if not maybe you could jump the connector.
Old Jan 8, 2011 | 09:57 AM
Switch should only be a single grounding wire. When grounded it shows as if the hood is open. Unplugging the wire should then show that the hood is closed.
A 2 wire ground switch just has the 2nd wire used as a ground because the sensor is not grounded to its mounting location. Connecting the 2 would then just loop the 2 causing the hood to seem open all the time.
But I am just going on my 20+ year experiance of being a car alarm installer. lol
Old Jan 8, 2011 | 11:34 AM
Haha, yeah IDK if i believe you.
Old Jan 9, 2011 | 01:30 AM
muurai's Avatar
haha woa man to much experince for me, if theres an easier way to say this i will appreciate it
how do i unplug it? it bothers me it just flashes cant even see the weather
etzbseder
Nov 2, 2011 11:39 AM
audibuyer
Mar 18, 2011 12:24 PM
NHolzschuh
Nov 29, 2010 12:25 PM
nypapaya
Aug 2, 2010 10:45 PM
