Headrest Mod, Moisture in Headlight Cluster
Old Apr 17, 2008 | 09:49 PM
vc1492a's Avatar
Default Headrest Mod, Moisture in Headlight Cluster
Switched the rear and front head rests and the front seats now look pretty sweet. They even look like theyve been made by recaro.
also, I have a lot of moisture in my left front headlamp cluster I cant get rid of, despite many days of sun. any ideas?
Old Apr 17, 2008 | 10:15 PM
The Wraith's Avatar
Default RE: Headrest Mod, Moisture in Headlight Cluster
This is what I would do...........
1.) Take the headlight housings out of the car.
2.) Remove the lamps/bulb housings to allow air to flow in.
3.) Let it dry out.
4.) Replace lamps/bulb housings.
5.) Inspect headlight housing for leaks/cracks ect.
6.) Seal leaks/cracks.
7.) Install headlights back in car.
8.) Use Meguiars 'Plastx' and a buffer to clean, polish and seal.
Old Apr 18, 2008 | 12:32 AM
jamesfreeman86's Avatar
Headrest mod???? never heard of this.. PLEASE enlighten me :-)
Old Apr 18, 2008 | 01:05 AM
ORIGINAL: The Wraith
3.) Let it dry out.
Or.... pull your headlights off the car and remove the actually lights so all you have is the housing. Put the headlight assembly in your oven. YES OVEN! at about 250-300 just for a couple minutes. You will see the glue on your housing will have bonded and dried a lot tighter around the assembly
Old Apr 18, 2008 | 04:02 PM
vc1492a's Avatar
headrest mod.
very simple but looks awesome.
just switch the rear and front headrests around. so back goes front and front goes back. the back doesnt look any stupider and then the front seats look awesome and much more sporty.
and thanks for the tips on the headlight cluster, thanks
Old Apr 18, 2008 | 06:57 PM
SO WILL THE BACK HEADRESTS BE LIFTED UP HIGH LIKE THEY WERE IN THE FRONT???
Old Apr 18, 2008 | 11:30 PM
vc1492a's Avatar
no they're much lower, and the front headrests in the back arnt up too high
Old Apr 19, 2008 | 09:04 PM
Ive been a lazy *** so i havnt done this yet. ima do it tomorrow and ill let u know how it goes. thanks
-btw go sign up here www.EuroForumz.com
Old Apr 23, 2008 | 02:03 PM
Notahondaowner's Avatar
I recently had the same problem with condensation in my pass side headlamp. I took out the entire light and noticed that one of the doors on the back of the low beam had broken where the metal clamp snapped down. Was 35 bucks for a new one from the dealer. I also took out my driver side light and noticed that this clamp had come off as well. With these little hatches open it is very easy for water to make it's way in.
raa4
Dec 6, 2013 01:31 PM
fade2black
Dec 1, 2008 09:24 PM
raa4
Feb 7, 2008 12:01 AM
2k S4
May 4, 2007 02:38 PM
Joeski
May 11, 2006 07:39 PM
