AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   Help on replacing my A4 B6 Foglight bulbs (https://www.audiforums.com/forum/b6-models-70/help-replacing-my-a4-b6-foglight-bulbs-178842/)
rlquattro2003 Jan 28, 2012 11:01 AM
Need help on replacing my A4 B6 Foglight Bulb, was able to pull it outbut not enough to remove the connectors? is it necessary to remove the entire bumper to do this? please help and would be very helpful if there are photos
spikezone2004 Jan 28, 2012 06:34 PM
sometimes the cables will get caught on the bumper, i took my foglights out couple days ago to put hids in and i had the same problem, make sure the 2 torx screws are out and then pull it to the side because theres two bits that go through holes on the other side of the torx screws that hold it in place aswell
rlquattro2003 Jan 29, 2012 12:43 PM
thanks, meaning the torx screw should be completely removed and the washers should be removed because its holding the cables? ill try it thanks.
spikezone2004 Jan 29, 2012 02:15 PM
the washers? there shouldnt be any washers too remove. post a pic of your fog light housing
pa4ul Jan 30, 2012 01:49 PM
by washers could he possibly mean the green tabs? nice look spike! U said the lowers are 8000k or 6000k?
spikezone2004 Jan 31, 2012 02:16 AM
Thanks man. The lowers are 8k and the headlights are 6k
rlquattro2003 Jan 31, 2012 07:00 PM
thanks guys, was able to pull it out already
