i keep getting code for idle rpm higher than expected
hey all, I can't for the life of me figure this code out. I've replaced some pcv lines and valves but the code still comes on after a while of driving.
If I clear the code, the idle drops down to normal. the idle will then start to creep up again :-(
here is a log from vagcom during idle. I logged block 002-032-060. I did 060 to see if the throttle plate was moving. It goes through the TBA fine. what concerns me is as idle goes up, MAF increases but the Injector on time stays about the same..
here are logs...
here are logs...
