instruction to replace coil pack?
Old Jul 1, 2009 | 12:22 PM
climber60614's Avatar
ok...thanks...auditech79...followed your advice...all is running well...however...cel is still on...anything I need to do to turn it off?...or just let it be?....also wondering if there is anything I need to do so as not to see the misfire code when I get it checked again at the Zone?
Old Jul 1, 2009 | 01:07 PM
Pablo_Ottawa's Avatar
Originally Posted by auditech79
The 3.0L packs are kind of a bitch to get at, you need to remove those little torx screws holding the harness down or you will break the connector to the packs. You REALLY don't want to do that so just take your time. If you don't have a T15 torx (super small) to pull the screws out, just use a small flat head screw driver or pliers to get them out, they aren't bolted in there real tight.
I never put them all back in either, completely unnecessary.
WOW I never read this part. Sorry guys, I thought it was more cut and dry.
As always, with regards to the CEL, get it scanned and find out what your fault codes are. If you live in Ottawa Ontario, I can do it for you.
Cheers
Old Jul 1, 2009 | 02:12 PM
kchao2000's Avatar
Does that apply to all B6 3.0L or just 3.0L Cab? I have 3.0L sedan and will replace the coils tomorrow.
Thanks.
Old Jul 1, 2009 | 02:37 PM
zippy_gg's Avatar
Thanks.
It does apply to all B6 3.0. I have a sedan as well and that is the way it is. Replacing a coil pack this evening to troubleshoot a rough engine issue.
Old Jul 1, 2009 | 02:38 PM
zippy_gg's Avatar
You need to clear the fault with a Vag-Com and then drive about 60-70 miles before re-scanning. You may be out of the woods!
Old Jul 1, 2009 | 03:18 PM
shane.trammell's Avatar
You don't have to clear it with a vag com. You can just use a regular code reader from autozone, which is free to rent.
Old Jul 1, 2009 | 10:13 PM
done...and done.........went to the Zone had them recheck...just in case I missed anything...had them erase the code and all is well....thanks for all the input...I'm sure it won't be the last time ..but...once it started running like a champ again...I remembered why I bought it....AAAAHHHHH
Old Jul 24, 2009 | 10:17 PM
  #18
Voodootv's Avatar
I'm a newbie and just wanted to thank the members of this forum for helping me diagnose a faulty coil pack on my 2004 Audi 1.8T this morning.
With the knowledge gleaned from this thread, I was able to remove and replace the faulty pack and get to an important appointment with minimal delay and expense.
I'm lucky - the original pack lasted 115,000 miles! We all have to go sometime.
Cheers,
Allan
Old Jul 26, 2009 | 12:51 PM
  #19
That's what we're all here for
Nov 20, 2010 03:40 PM
kraylon
Jul 29, 2009 12:19 AM
AudiATX
Sep 9, 2008 10:12 AM
BoostinA41.8t
Nov 24, 2007 06:56 PM
flipstrt
Jan 25, 2007 08:35 PM
