Intake Flap Motor? Keeps misfiring and have replaced coils/plugs
Hi all.
I've searched and searched and can't find an end to my misfire problem. All the coils have been replaced, all the spark plugs, and I finally took it to the dealer and they said I need a new intake flap motor. I will always try to do things myself first, but i can barely find a single thing on an intake flap motor (for a 2002 3l V6 A4) and can't find anything in the bentley/eBahn repair program or on google. Is it called anything else? Any help would be appreciated so much. |
Are you sure the dealer said it was "Intake flap motor"?
I think they are talking about the "Intake change-over valve" in intake manifold runner of your 3.0L engine. If this valve is sticky or broken apart inside, it will cause lack of power and misfire under acceleration (especially around 4200 rpm or more) The car will most likely idle very normal and run ok at steady speed. |
Originally Posted by treelimb
(Post 1089056)
I think they are talking about the "Intake change-over valve" in intake manifold runner of your 3.0L engine. If this valve is sticky or broken apart inside, it will cause lack of power and misfire under acceleration (especially around 4200 rpm or more) The car will most likely idle very normal and run ok at steady speed. I am thinking about replacing the changeover valve anyway, as the plastic is very worn down and it is missing a spring that exists in the exploded view of the repair guide. |
Air Intake... Some airboxes have a flapper that opens/closes during acceleration.
www.audizine.com/forum/showthread.php?t=278253 forums.vwvortex.com/zerothread?id=4332376 |
Misfires occur because of one of three reasons.
No spark OR No fuel OR No air Check fuel filter Air filter And anything else that has to do with sending spar, fuel and air to your engine. |
Originally Posted by Midniteoyl
(Post 1089417)
www.audizine.com/forum/showthread.php?t=278253 forums.vwvortex.com/zerothread?id=4332376 In that case, i'm thinking this may not even exist on my car and that the mechanic either misspoke or isn't as trustworthy as I thought.
Originally Posted by Pablo_Ottawa
(Post 1089476)
Dammm. Sorry dude, I have no clue but I'll bet there is someone here who does :)
Quote: Originally Posted by Midniteoyl Air Intake... Some airboxes have a flapper that opens/closes during acceleration. www.audizine.com/forum/showthread.php?t=278253 forums.vwvortex.com/zerothread?id=4332376 I saw this before, and it seems to be applicable only to 05+s and some 04s, so I don't think that it exists on my 02. In that case, i'm thinking this may not even exist on my car and that the mechanic either misspoke or isn't as trustworthy as I thought. |
Originally Posted by jsoverson
(Post 1089341)
Positive he said intake flap motor, and it is even written. The car doesn't idle very well, it vibrates as if it is misfiring even at a fresh start.
I am thinking about replacing the changeover valve anyway, as the plastic is very worn down and it is missing a spring that exists in the exploded view of the repair guide. I think you need to talk to your mechanic (Not service advisor) to comfirm about the "intake flap motor" on your 3.0L A4 because it doesn't have it. If you did go that far to see the missing spring in the change-over valve, you may see it may be broken apart. Make sure no borken piece stays in the intake after replacing the change-over valve. |
