key remote help
Old Apr 2, 2009 | 11:01 PM
dasBoost's Avatar
Default key remote help
so im not stranger to batteries dying in key remotes.
but what the hell is wrong with it when u replace the battery and it still dosent work?
im just tired of using my key to get in the door.
Old Apr 6, 2009 | 03:45 PM
knerml's Avatar
Member
Suggestions:
1. Make sure the battery is installed properly.
2. Get another new battery.
3. Try reinstalling the battery, several times.
Old Apr 6, 2009 | 04:39 PM
Dylan19's Avatar
i have never tried but im pretty sure you need to have the dealership program it. and i think they need the spare key too.
Old Apr 7, 2009 | 02:53 PM
audistheonlyone's Avatar
when you replace the battery, you have to put the key in the ignition, turn it to on, but dont start it, then while its turned to the on position, press the lock and then press unlock button on the remote. turn the key to off, pull it out and see if it works.. thats what i had to do to it when i replaced mine.
Old Apr 7, 2009 | 02:54 PM
knerml's Avatar
Member
There should be instructions for adapting remote in the owners manual.
Old Apr 7, 2009 | 10:21 PM
dasBoost's Avatar
replaced battery. took it out of remote several times. tried the programing noted in manual. went to dealer and they said the reciver inside the car might be dead. and its only like 400 bux. thank god for STEALERships right? ill try the key bit. thanx so far. ill keep u guys posted.
also. wheres some websites to get OEM parts/ replacement parts. and, or mods. its auto with the CVT tranny so im not gonna do to much but any little helps i guess.
Old Apr 8, 2009 | 03:03 PM
dasBoost's Avatar
well damn, i tried everything that everyone has said to try. still nothing. is there anyway to tell if your remote is toast? ive done pretty much everything. or how can you tell if the in-car reciver is toast? dammit!
Old May 2, 2009 | 05:05 PM
zelembac's Avatar
Default receiver inside the car
Hi there
I Have same problem. Do you know where is receiver located. I have phone for used Audi parts 1800 255 2834 with 6 mounts warranty. But I have to give them part number.
Thank you and good luck
Max
Old May 3, 2009 | 08:24 PM
muckdawg24's Avatar
Originally Posted by zelembac
Hi there
Max
Receiver is located under the headliner in the rear of the roof.
AudiGirl92
B7 Models
Aug 31, 2013 08:28 AM
MartinCieslak1
Dec 11, 2009 02:30 PM
krshrk
B8 Models
Sep 18, 2009 07:08 PM
Albee G
Mar 9, 2008 08:21 AM
marcink99
Jan 26, 2008 10:09 PM
