Lots of questions please help a new comer
any dv u install in the audi will need to be reversed from the stock dv. AS for the ecu flash i would stick wit the major companies. APR GIAC are some of the more popular. . .
:: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
no problem man we are all here to help. Just be kind and kind people will help. the flash is a chip. The go into the ecu and reprogram the metering on the car to achieve its true potential. its the quickest way to spend 500 dollars but wakes up the car considerably.
http://motozaperformance.com/MotozaPS.html this is the one I have been looking into. Sounds like you plug it in email them the results and they send you a new program back
QUOTE=pa4ul;1410915]no problem man we are all here to help. Just be kind and kind people will help. the flash is a chip. The go into the ecu and reprogram the metering on the car to achieve its true potential. its the quickest way to spend 500 dollars but wakes up the car considerably.[/QUOTE]
MotozaPerformance
This is 100% for sure the way I'm going when/if I can justify spending money on my car for fun.
Right over 300 I believe which is 40 percent cheaper then many others I'm seeing.
QUOTE=pa4ul;1411138]IT is. Ive heard other people using that brand. They say its really good cuz u get the vagcom with it so monitor your car. How much is the whole program going to run if u dont mind my asking?[/QUOTE]
