Lotsa Lights ON! CEL, etc
All,
Happy Thursday!
Help!
I'm experiencing the following with my 2002 Audi A4 3.0 82000 miles:
*Check engine light ON- flashes (stays still @ times)
*Hood light- blinks as though the hood is not closed; however it is. (I think this is a broken sensor?)
*Service Light ON- abt a week now
I'm taking the Audi to the dealership 1st thing in the morning. Irequested a service which I was quoted $450 and the service manager suggestedto get a timing belt joband oil changeinstead.....ONLY $1900. The service manager advised that he has seen too many times were the timing belt breaks before the ownermanuals suggested replace.He also suggested that I get a service @ 90,000 instead. He wants to do prevented maintenance I guess?Also I took myAudi to Auto Zonetoday andmycheck engine codes read as follows:
P0741, P0302, P0303, P0301, P0300, P0015, P0021, P0421 & P0431.Will someone pleaseexplain what this means to me? Are these costly repairs.Could a GOODmechanic easily work on Audi's are should I always have Audi certified technicians under the hood (dealership)?
Thanks in Advance,
damselndistress
Happy Thursday!
Help!
Thanks in Advance,
damselndistress
For the 1.8 T motor, the flashing CEL means that you could be damaging your catalytic converter. Do you feel the motor running a bit rough? A bad coil pack on one cylinder would cause that and give the flashing CEL. Also for the 1.8 T motor, the timing belt and tensioner are suppose to be replaced at 80,000 miles. Not sure about the 3.0 though. You can look up engine codes here on the site to find out their exact meaning.
damsel ... looks like you have alot of problems on your hands. your coils are most likely bad, your transmissionseems shot, your catalytic converters seem shot, or it could just be your 02 sensors.your timing seems shot. you own a 3.0 so sounds like youre in for an expensive repair tab. I'm not a tech or anything so i cant say anything withcertainty... thedealer will charge you too much. find an independent shop thatsknowledgable withaudis.
g'luck
17125/P0741/001857 - Torque Converter Clutch: Stuck OFF / No Power being transferred
Possible Causes
[ul][*]Automatic Transmission Fluid (ATF) Level not OK
[ul][*]Transmission Sealing faulty [/ul][*]Automatic Transmission Fluid (ATF) dirty[*]Torque Converter faulty or incorrect Torque Converter installed[*]Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218) faulty[*]Torque Converter Pressure Valve faulty[*]Valve for Torque Converter Clutch faulty[*]Torque Converter Lock-Up Clutch faulty/worn our [/ul]
Possible Solutions
[ul][*]Check Automatic Transmission Fluid (ATF) Level
[ul][*]Check Transmission Sealing [/ul][*]Check Automatic Transmission Fluid (ATF)[*]Check Torque Converter[*]Check Solenoid Valve 7 (N94)/Pressure Regulating Valve 4 (N218)[*]Check Torque Converter Pressure Valve[*]Check Valve for Torque Converter Clutch[*]Check Torque Converter Lock-Up Clutch [/ul]
1.2 Special Notes
if (window.showTocToggle) { var tocShowText = "show"; var tocHideText = "hide"; showTocToggle(); }
16686/P0302/000770 - Cylinder 2 Misfire Detected
Possible Causes
[ul][*]Ignition system[*]Fuel injectors[*]Fuel pressure[*]Running out of fuel[*]EVAP canister purge valve[*]Evaporative emission system[*]Low compression[*]Base engine problems[*]Controle Module damaged [/ul]
Special Notes
[ul][*]This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.[/ul]
16687/P0303/000771 - Cylinder 3 Misfire Detected
16685/P0301/000769 - Cylinder 1 Misfire Detected
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Possible Causes
[ul][*]Air Intake System leaking[*]Fuel Supply faulty[*]Injector(s) faulty[*]Ignition Cable(s) and/or Spark Plug(s) faulty[*]Ignition Coil(s) faulty[*]Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open[*]Camshaft Position Sensor (G40) faulty [/ul]
Possible Solutions
[ul][*]Check Misfire Recognition[*]Check Air Intake System[*]Check Fuel Supply[*]Check Injector(s) and Injector Sealing[*]Check Ignition Cable(s) and Spark Plug(s)[*]Check Ignition Coil(s)[*]Check Exhaust Gas Recirculation (EGR) Valve (N18)[*]Check Camshaft Position Sensor (G40) [/ul]
16815/P0431/001073 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
Possible Causes
[ul][*]Warm Up Catalyst Bank 2 faulty [/ul]
Possible Solutions
[ul][*]Check Warm Up Catalyst Bank 2
[ul][*]Set Readiness [/ul][*]Replace Warm Up Catalyst Bank 2[/ul]
P0421 Warm Up Catalyst Efficiency Below Threshold Bank 1
g'luck
Possible Causes
Possible Solutions
1.2 Special Notes
Possible Causes
Special Notes
Possible Causes
Possible Solutions
Possible Causes
Possible Solutions
P0015
"B" Camshaft Position - Timing Over-Retarded, Bank 1
P0021
"A" Camshaft Position - Timing Over-Advanced or System
Performance, Bank 2
Thanks for thereplies guys!
Update......
Audi Loaner Car.......No Charge!
L/F Turn Signal Bulb & Holder & Taillight Bulb......$31.69
Oil & Filter Change.......$61.60
Dignostic........$114.00
Hood Lock (sensor).......$259.59
Timing Belt ............$1900.00 (recommended)
Both Catalytic Converters.........$2849.64
***Over the miles for warranty replacement of converters!
Getting a less expensive car..............PRICELESS
Update......
desertsnake1991
Apr 22, 2012 10:05 AM
