Whine when turning
Whine when turning
I have a 2004 A4 Cabriolet 3.0 Quattro. When turning there seems to be a whine coming out of the front. I have approx. 28000 miles on the car and it is my first Quattro. Is the noise typical for Quatrros??
If ur car whines when you turn then you're probably low on power steering fluid. Go get some, make sure it's the right type, top it off to the fill line, leave the cap off and run the car until ALL of the little bubbles are gone, put the cap back on and u should be good. If this happen often like once a month or so, you would more than likely have a leak.
The right fluid and fluid level is crucial! We have it available below!
Click HERE to order or for more information.
Jason
Jason
Nevalite
08-13-2012 03:04 PM
chesterfan1230
04-17-2011 06:41 PM
