Multiple miss fires
Old Jul 14, 2009 | 10:33 PM
riggs5's Avatar
Default Multiple miss fires
I have been trying to fix a check engine problem. I have been working on this problem for a few months. I have codes P0301 P0303 P0302 P0304 multiple miss fires on Cyl 1-3-2-4. I've been working with an Audi mechanic and we have looked at CO sensors, vacuum leaks, smoke testing, ECU, Hot wire, fuel pressure, fuel rate, plugs and replaced 4 coil packs and spark plugs.
Is their anything I missed, any Audi geniuses that have some more ideas?
Thanks
Old Jul 16, 2009 | 03:16 PM
andyzzdae38's Avatar
Member
Have your mechanic check the fuel injectors. Ohm them out and use a noid light to make sure they are firing.
Old Jul 16, 2009 | 09:35 PM
audiprotein's Avatar
^^^ i was about to day that...
also, question to you OP, did anyone install any new software on your car? or did anyone raise your idle with VagCom?
Chuckbarry
May 10, 2012 09:58 AM
cschmitt
May 17, 2010 11:43 AM
cjh807
Jan 7, 2008 09:38 PM
biddi
Oct 28, 2007 01:51 PM
