Need help! misfiring and i want to commit suicide
Old Jul 23, 2009 | 06:04 PM
chrben22's Avatar
Default Need help! misfiring and i want to commit suicide
i'm really about to jump off a bridge now...
my friend ran the scanner thing and i replaced all my coil packs on the drivers side of the car
the codes said misfire 4, 5, 6. i just had plugs done last year (oem NGK's)..... still have a flashing light in my face.......
what else could this possibly be? could the plugs be bad? and i can smell the heat coming off the cat so i'm sure it's not a injector/fuel problem...i don't know what to do anymore i've exhausted all options....
please help!
P.S. it use to do this off and on for a while and i would just shut the car off and let it rest and it would start up with no problems....i also tried the marty mcfly and smashed my head on the steering wheel and that didn't work either...
2002 A4 3.0 Quattro six speed
thanks
Old Jul 23, 2009 | 06:32 PM
shane.trammell's Avatar
Is it still running badly? Have you tried clearing the codes?
Old Jul 23, 2009 | 07:22 PM
chrben22's Avatar
would that make a difference?
Old Jul 23, 2009 | 07:26 PM
chrben22's Avatar
could it possibly be the fuel rail if the whole side is bad? the car is extremely hot and it's exhaust hot too.....maybe it's not getting enough fuel?
Old Jul 23, 2009 | 10:08 PM
pa4ul's Avatar
does it studder only at idle or all the time. If its only at idle it could possible be a fuel pump or fuel related.
Old Jul 23, 2009 | 11:00 PM
chrben22's Avatar
it's misfiring at idle and while driving.....we hooked up the computer to it and it was misfiring like crazy.
it's a mystery.
Old Jul 24, 2009 | 01:46 AM
Mike-2ptzero's Avatar
I would start off by doing a compression test on those cylinders which are all on one bank. Then check the fuel correction numbers using a vagcom. Swap injectors bank to bank to see if the misfire issue jumps to the other bank of cylinders.
Old Jul 24, 2009 | 11:51 AM
pa4ul's Avatar
maybe clean your maf
Old Jul 25, 2009 | 02:55 PM
Pablo_Ottawa's Avatar
A cylinder will misfire if it's not getting enough
A) Fuel
B) Spark
C) Air
So it has to be anything related to that. Try replacing the fuel filter and air filter. Two cheap diagnostic steps.
Old Jul 25, 2009 | 03:54 PM
Midniteoyl's Avatar
Has anyone check (or played with) the cam timing?
