Noise @ 2800 - 3000RPM
2002 Audi A4 1.8T stock 106,000 miles---I'm getting a strange noise, I think it may be in the exhaust - it's quiet until the engine gets warmed up for about 10 minutes. Almost sounds like my muffler is gargling or something and it only sounds that way from around 2800 - 3000 RPM's then it disappears. Any of you experience this? Just trying to find out if it's something I can correct without taking it into a shop.
Thanks and Happy 4th of July!!
Took it over and put it on the lift, there is no hole in the exhaust system. However we did figure out that the noise is coming from part of the exhaust system but is apparently a vibration inside?
On the 2002 1.8t, the exhaust starts at the manifold, goes into a catalytic converter, runs back as a single pipe into a muffler and exits the muffler as dual exhaust pipes which then have another box that each travel through at the very back of the car before coming out as the tail pipe.
The vibration is in the box on the passenger side exhaust, just in front of the tail pipe.
What is this box, some type of resonator for the exhaust?
So over the weekend we found a vibration in the passenger side resonator on the exhaust.... I had mentioned that I had seen a loss in gas milage - i based this on how many miles I get to a tank, which in the past had always been right at 400 miles. When we were searching for the source of the vibration we shook the passenger side exhaust pipe. I filled up today but my fuel gauge still shows 3/4 of a tank.
Question is - does the fuel float mechanism in the tank sit on top of the passenger side resonator and could these two issues be related? Could something have become lose, and touch the resonator causing the sound? Could we have severed the wiring or something?
The guage still jumps from E to 1/4 tank but won't go over.
But I just put 16 gallons of fuel in it.
Once again thanks for your time and advice...
