One touch windows
Old Jun 11, 2008 | 01:15 PM
pa4ul's Avatar
Default One touch windows
2003 a4 1.8t front passenger side windows one touch isnt working anymore any idea on how to get it back to proper function?
Old Jun 12, 2008 | 12:23 PM
Mike-2ptzero's Avatar
Default RE: One touch windows
Hold the button for a few seconds after the window is fully up, this will reprogram it for one touch up.
Old Jun 12, 2008 | 12:55 PM
pa4ul's Avatar
My one touch up works still but the one touch down dosent. any other insights?
Old Jun 12, 2008 | 01:00 PM
kolbs_91's Avatar
Does your window make any popping or grinding noises when you put it up or down?? I'm thinking it could be a warn out regulator, but I may be way off.
Old Jun 12, 2008 | 08:40 PM
harryd14's Avatar
or perhaps try the opposite of what the guy said about the one touch up not working... just an idea
Old Jun 13, 2008 | 09:16 AM
Flip's Avatar
My regulator on my old 2001 A4 went out, it makes a clicking sound when the window is going up. Does yours do anything along those lines?
Old Jun 13, 2008 | 11:49 AM
pa4ul's Avatar
windows got up and down fine. no noises or anything i tried to hold the button their for 10 seconds 15 seconds twenty seconds. nothing. does the key have to be in the on positon or something or off position.
Old Jun 13, 2008 | 12:01 PM
techbod's Avatar
press the down all the way keep it pressed and the up all the way and it will reset or beep confirming it
Old Jun 13, 2008 | 12:18 PM
pa4ul's Avatar
ok ill try again does it matter if the key is on or the car on or anything>?
Old Jun 13, 2008 | 12:28 PM
techbod's Avatar
ignition on to aux then operarate the windows and ensure they open all the way down ( keep the button pressed ) and do the same to close the system should beep to inform you that its set
