p0420 code completely confused HELP PLEASE!!!!!!!
I used 034 motorsports 02 spacer and had no CEL (p0420) for about 5000 miles. The only time I have a problem is when I run over 90mph, I then get a 02 Temp. code. Your rear 02 might be too much out of the air stream. Try a diffrent spacer! The only other things I can think of is the flex pipe cracked, Cat almost completly clogged.....
yeah the cat is still under warranty so im not that worried so i will keep you guys posted. thanks for all the help. im under warranty until like 8 months from now so i may not do it till then because im in school and such. but when i do i will let yall know. i just switched to only one short drilled spacer to see what that does and then if that doesnt work i will go back to the 2 again and then 3 maybe until this upcoming summer
i would get that cat swapped quick if u are under warranty still. Im still saying its your cat and those non foulers arent going to work. It might rid the problem for a little while but eventually it will show up again. If i had the choice i woulda swapped my cat first thing! u lose alot of gas mileage running around with that code!
my gas mileage is about 30 - 35 mpg so my mileage is great. i cant fork out 1200 for a new Audi catalytic converter due to the fact that i also have to pay tuition. and yes i know i can get a different type of cat but it will most likely throw the same code. spacers work
