Please help me, i could use it, engine sputtering and car shaking
Old Mar 4, 2012 | 09:38 PM
synergy04's Avatar
Default Please help me, i could use it, engine sputtering and car shaking
2004 a4 1.8t with 108k on it. I started my car today and my car started to sputter and shake quite a bit. I just had it at the dealer a few weeks ago and they checked and replaced my coil packs. Never had a problem until now. I started to look into possible common issues and found that it could be exactly this. Which would also explain why ny exhaust smells like straight gas because its not all gettin burned, am I correct?
Old Mar 5, 2012 | 12:58 PM
pa4ul's Avatar
could also be a vac leak. Or ur connectors on your cp not being fully seated.
Old Mar 6, 2012 | 12:44 AM
synergy04's Avatar
I went and got it scanned, after it came back as all 4 misfired, we looked around the engine bay a bit. The most we really did was jiggle the maf sensor, I got out of the parking lot and it drove normal, 5 hours later, no more CEL either. I'm gonna take the maf off and clean it, that should help prolong this luck
Old Mar 6, 2012 | 09:49 AM
Pablo_Ottawa's Avatar
1. Car was fine before you took it to dealer (I assume so)
2. Dealer replaces coil packs
3. Car now having problems
Solution= the coil packs plain and simple
It's the most logical deduction so you should be looking at that first. Take them out (not hard to do), inspect them and put them back on. Also, check your spark plugs and the spacing. .032 if it's non chipped and .028 if it is.
Old Mar 6, 2012 | 09:51 AM
esandes's Avatar
Banned
are you using a K&N filter? the oil from those is known to mess up MAF sensors.
Old Mar 6, 2012 | 02:29 PM
pa4ul's Avatar
Truth spoken. for future users if u get a k&n let it dry out for a while 15 to 30 minutes. Then install it. same deal when u recharge it. Dont over oil it.
Old Mar 7, 2012 | 02:37 AM
synergy04's Avatar
My car is all stock. I haven't done anything to it yet, only had it a short while. It runs perfect again, its like she had her period and felt like being a worrisome bitch. I love her but man, that was uncalled-for. So of its running fine again, I'm gonna leave it for now and bitch at the dealer when I have time.
Old Mar 10, 2012 | 09:58 PM
jamie1210's Avatar
i have a 3.0 2002 and put a piper cross air filter in hope of a better sound. but in less then two weeks i got lights up on the dash and the car was driveing like s..t even cutting out. it messed up my air mass sensor. so got it all off the car and put it back to stock cleaned the air mass and reset computer all fine now.
Old Mar 11, 2012 | 07:55 PM
aspen79's Avatar
All 4 cyl misfire codes stored, chances of it being a coil problem are slim to none. Sounds like theres a sporadic high resistance in the MAF connector terminals. All it takes is the slightest corrsion and the signal is messed up. I don't mean CORROSION, but an invisible corrosion, almost like a coating that you'll never see. We use a product called DeoxIt. It's made specifically for electronic circuits such as this.
DeoxIT® D-Series
06AFOUR
Jan 17, 2011 12:19 PM
joncowden
Jul 6, 2010 06:42 PM
vampyre308
Mar 15, 2010 07:35 PM
jeitjet
Jul 20, 2008 03:27 AM
smallfry
Jan 23, 2007 11:22 PM
