remote fob cannot be programmed
Old Sep 8, 2012 | 07:05 PM
Google44's Avatar
Unhappy remote fob cannot be programmed
Hi everyone
My remote fob cannot be programmed for remote lock/unlock. So far this is known:
1. all fuses are OK
2. remote tested in two places and is radio transmitting ok + has new battery
3. try to program it by turning ign on while holding unlock for 3 sec then ign off
so far no luck. Method defo works as I've tried it on friends b6
4. interior light next to review mirror does not work either.
5. central locking and alarm operate on key.
please help
Old Sep 10, 2012 | 03:20 PM
pa4ul's Avatar
have u tried sticking the key in the door and locking hold for 3 seconds while pushing the unlock button on the fob. reverse and do the same with the unlock 3 seconds hit button. Then go into car and turn on. Might take a drive to get it to resync. at least i think thats how it went. Been a long time since i had to resync the key.
Old Sep 10, 2012 | 05:12 PM
Google44's Avatar
Thanks for advice. I've finally disconnected battery for 10 mins then connect it back on then programmed the key and it is fine now. It does loose it now and again but at least it works. So it needed a good reset
now I need wiring diagram for dome light and door lock. Guess that requires a new thread
Thanks
Old Sep 11, 2012 | 11:53 AM
pa4ul's Avatar
for ur other problem have you check the fuses yet? I forget which one is for the interior. There should be a diagram of the fuses on the back of the panel when u pull it off to see the fuses.
stonevs
Oct 24, 2015 09:54 AM
porschefan
Sep 9, 2009 12:54 PM
Bklynrx7
Mar 31, 2009 11:42 PM
VTEC_THIS
Oct 24, 2008 10:55 PM
