Rough Idle
I have a problem with a rough idle. The dealer and a few independent Audi mechanics can't find what the issue is. I get average fuel mileage (24mpg hwy) and performance seems good, mostly at stops do I notice the idle being rough. Audi wants me to drop the A4 off a the dealer and have them use Audi tech to do a parts exchange game. I'm hoping someone has had a similar problem and can offer some suggestions.
04 A4 3.0 144K miles, Check engine codes; P0432, P0421, P0300, P0301-02-03-04 Replaced; 6 Coil Paks. Recall (replaced 4 CP's 18 months ago) Fuel Pump w filter 6 spark plugs CAM sensors. Cleaned the fuel system, injectors clean by Dealer Checked for a vacuum leaks, Fuel pressure, Fuel rails & balance, Replaced and reflashed ECM, hot wire cleaned checked. All with no problems. Any Ideas? :cool: https://www.audiforums.com/forum/alb...pictureid=3042 |
is it only when its in drive at a stop light or is it in any gear?
If its only in drive it could be transmisson mounts |
I'm not sure, I notice the rough idle wile stopped. Someone else asked if the car was missing wile I was driving. I would need to dive and look[IMG][/IMG] at the codes to see what comes up.
https://www.audiforums.com/forum/pic...pictureid=9168 |
