AudiForums.com
-   B6 Models (https://www.audiforums.com/forum/b6-models-70/)
-   -   spark plugs (https://www.audiforums.com/forum/b6-models-70/spark-plugs-103081/)
CoBra03TerminAtoR May 22, 2008 11:16 PM
spark plugs
hey guys what do you think of the ngk iridium lx spark plugs? also how about the coil packs from ecs tuning?
acollicott May 23, 2008 12:26 AM
RE: spark plugs
ECS is a pretty good place to buy from, I've gotten quite a bit of stuff from them and I've been happy with them so far.
I think most people on here are rocking NGK plugs. I'm running the BKR7E, but I think the Irdiums are better for the V6ers
kolbs_91 May 23, 2008 12:28 AM
RE: spark plugs
I had the intention of getting NGK the first time I changed mine, but ended up with Denso Iridiums. I've been very happy with them.
Pablo_Ottawa May 23, 2008 06:20 AM
RE: spark plugs
I use em and I think they're pretty good... I mean honestly, A spark plug is a spark plug... Iridium, copper, platinum, They all do the same job and won;t really increase your HP. Some will just last longer than others. Get what you want just don;t go cheap because then you may start to see a difference in fuel economy. I heard of a plug with a round contact which made a HUGE spark and apparently it REALLY boosts your MPG. Sadly though it's not available for Audis :(
CoBra03TerminAtoR May 23, 2008 07:53 AM
RE: spark plugs
alrightthanks for the input guys... i was just kinda curious because the same ngk plugs from ecs are 64 dollars, as compaired to 18 a piece from advance auto!!!!!!... and what about coil packs from advance? i need to change them nd id rather just buy the iridium plugs and a set of coils from advance rather than waiting untill next week sometime to get them in
AudiOso May 23, 2008 08:07 AM
RE: spark plugs
Are your coilpacks currently giving you a problem or are you buying spares? If they aren't misfiring then there is no reason to replace them as far as I understand.
I'm running the Denso Iridiums. I got them for the long plug life. I didn't expect any performance gains.
CoBra03TerminAtoR May 23, 2008 08:13 AM
RE: spark plugs
yeah they are misfiring, but only when the car is cold.... but none the less they should be done, i am going to do all six just to get them out of the way... not going for performance at all..
