spark plugs
what kind of spark plugs should i buy???? whats best? how do i know
i live in socal,,,,,los angeles,,,,,, its usually hot out here...but the weather can be bi polar at times. what company is best and how much do they cost???
Copper plugs are the best way to go on a turbo car, not sure what you have because you gave no info about what you own.
If you are chipped K03 then you want to go 1 step colder then stock.
monsterrider - yes. Just unplug it and then pull it straight up.
For driver side, you may want to remove coolant reservoir (not remove it completely, just loose it up so you can push it aside). For passenger side you need to remove air intake, some plastic covers. Otherwise, you may not have enough room to work on it.
It's not hard but just a bit of PITA.
