Stereo Wiring
Old Dec 11, 2011 | 08:52 PM
gio64's Avatar
Default Stereo Wiring
Hi everyone,
I have spent the better part of the weekend hunting down information about my symphony head unit (that died) so I could get a new unit wired up.
I believe I have a pretty solid understanding of every wire I need to consider, however, I need a switched 12 v and although somebody has told me that I can get it from the heated seats, I tried to determine with the multimeter which of the wires going into the climate control carries switched 12 v, but either the multimeter doesn't work, or I am an idiot, or I am just having bad luck.
I tried each plug (there has to be at least 5 in the back of the climate control and I can't get a 12 v readout.
If this can help, I have determined which of the plugs powers it up, but after attempting to determine which of those wires is a switched 12, I can't piece it together.
Can anybody tell me if they know which wire in the climate control/heated seats block carries switched power?
Thank you.
Old Dec 15, 2011 | 04:28 AM
BurtonRider8's Avatar
So you're trying to put an aftermarket head unit in? When I put mine in I couldn't find a 12V source either, so I ran a line over to the fuse box, not a great solution, but it's worked so far.
Old Dec 15, 2011 | 08:27 AM
gio64's Avatar
Thanks for the feedback, I ended up doing that as well. All's working.
Old Dec 19, 2011 | 11:34 AM
charlie_murphy's Avatar
Having the same problem. Which fuse did you end up plugging it into?
Old Dec 20, 2011 | 11:19 AM
gio64's Avatar
I went to the fuse box and hooked up to the -IIRC- stereo fuse, which is switched. I was doing it with a friend of mine and he ended up hooking the wire up after I ran it from the stereo location to the fuse box, but I can double-check if you want me to.
EL LOCO 64
Apr 21, 2008 09:22 PM
Deanne
Dec 12, 2007 12:46 PM
randomtask37
Jul 21, 2006 02:16 AM
Speedracer1
Oct 4, 2005 02:21 AM
BoostedA4
Apr 8, 2003 06:27 PM
