System too lean questions
Old Jul 9, 2008 | 02:05 PM
shellsaudi7706's Avatar
Default System too lean questions
I got my CEL read and it has 2 codes, P0171 and P0174 which code for system too lean bank 1 and system too lean bank 2 respectively. My first question is what does that mean and my second question is what are the odds of both banks being "too lean"? Could my problem be before the banks split apart?
I have a 2002 3.0 A4 quattro.
Old Jul 9, 2008 | 05:12 PM
auditech79's Avatar
Default RE: System too lean questions
It means there is either a large vaccum leak, maybe near the brake booster. You should be able to hear a large hissing noise around the engine if this is the case.
Or your MAF sensor is faulty.
Old Jul 9, 2008 | 05:34 PM
audiprotein's Avatar
Search will help you
https://www.audiforums.com/m_246370/tm.htm
Most likely it some an air leak, or you o2 sensor/maf
The car runs lean when it doesn get enough of lets say air (for example).
Old Jul 9, 2008 | 05:51 PM
I appreciate you both for your advice, I'll check it out.
wings7351
Oct 30, 2009 08:17 AM
bartusxpl
Aug 6, 2009 09:37 PM
skibum0019
Feb 10, 2008 08:06 PM
viktor008
Nov 1, 2007 12:51 PM
NeXeA500
Oct 11, 2006 07:42 PM
