Thermostat Question
Old 03-05-2010, 05:08 PM
Default Thermostat Question
Hello fellow Audi owners. I have an '02 A4 Quattro w/ the 1.8L Turbo. I have a P1296 code and have replaced the CTS. The CEL was re-set and reappeared after a couple hours w/ the same P1296 code. I am looking at replacing the thermostat as the next step. My interior temperature guage stays near cold for the first 30 minutes or so of any drive, then the needle usually heads toward the center of the guage. It often then heads back toward the cold end about 1/4 of the way between cold and hot. The water pump is working fine and the anti-freeze level is appropriate.
1. Do you think it's a thermostat issue?
2. Do I need to replace just the thermostat (~$20 part) or the whole thermostat housing and assembly (~$100 part)?
Thanks in advance for your feedback!
Old 03-05-2010, 05:28 PM
you need to call a dealership and check the part no with your vin. i had to use this one in my 02 [url]http://www.aboveallmotorwerks.com/BVModules/ProductTemplates/Bvc%202004%20layout/Product.aspx?productid=BEHR THERMOT-TRONIK_06B121111K
seditious3
08-02-2011 09:03 PM
hahaha251251
01-29-2010 06:54 PM
SteveH
03-12-2008 02:46 PM
cdnskier
06-14-2005 03:52 AM
audihere
02-20-2005 02:38 PM
Quick Reply: Thermostat Question
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
